Ana içeriğe geç
Kasım 2016'da piyasaya sürülen PS4 Pro, 4K oyun ve video akışı için yükseltilmiş donanıma sahiptir. Modeli: CUH-7015B.
DVD problem and stability issue
Hi everyone, I bought a PS4 Pro and it appears to be working perfectly. At first glance everything seems to be fine, just a little slow in loading the system. I try the DVD player, and when I install the games it installs them, but makes strange noises as if it's struggling. I thought it was the reader that was faulty, perhaps the lens, when in the evening I turned it back on and it checked the database, failing, and after a couple of attempts (not even accepting the manual update), it turned back on as if nothing had happened. Now, given that the system in general seems quite slow, could it be a nearly dead hard drive? Or is the reader giving in too? Maybe the lens?
Bu iyi bir soru mu?
Puan 0
Yorum Ekle
1 Cevap
Filtre ölçütü:
Seçilen Çözüm
Hi there!
According to your issue, it does look like that the Hard drive is getting bad.
I recommend to replace this one first and see how that goes!
While you are there, maybe it's worth it to replace it for an SSD! Faster, less power consumption etc.
When replaced, you need to install the new PS4 software on it, which can be found here: https://www.playstation.com/en-us/suppor...
Make sure you get the "PS4 Console Reinstallation File". Not the update file.
Guide for how to replace the HDD: PlayStation 4 Pro Hard Drive Replacement It's really easy to do!
Please let us know how it goes!
Bu yanıt yardımcı oldu mu?
Puan 1
4 Yorum:
Alright, i'm gonna replace it and see the results!
tarafından
Great! HDD drives could also make some noise (when they are starting to die). Please let us know how it goes and good luck!!
tarafından
Hi, i swapped out my old hdd with a new ssd, and it works flawless! Thanks a lot, problem solved!
tarafından
Good to hear!! Have fun gaming and take care :)!
tarafından
Yorum Ekle
Yanıtını ekle
Lollo Modding sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 6
Son 30 gün: 23
Her zaman: 177
