Ana içeriğe geç
Asus'un ROG ürün grubundan çıkan bir oyun dizüstü bilgisayarı. Bu sayfa, ROG Strix G16 dizüstü bilgisayarınızın parçalarını onarmanıza/değiştirmenize yardımcı olacaktır.
New Laptop - Second HD Inaccessible
I purchased ROG Strix G16 and realized the hard drive was too small to install all of my games onto. I contacted the seller and they recommended buying a 1T internal hard drive along with instructions since there was an extra slot available. I have the extra drive installed, but it's not registering. What do I need to do so it's recognized and functional?
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 0
3 Yorum
It's not registering as in you can't see it in File Explorer? Or it's not showing in BIOS?
tarafından
I can't see it in explorer - It's there in device manager, but cannot access it normally
tarafından
I have the answer to my question using these links provided by a friend - in case anyone else has the same issue: https://learn.microsoft.com/en-us/window..., https://learn.microsoft.com/en-us/troubl..., and https://learn.microsoft.com/en-us/troubl...
tarafından
Yorum Ekle
2 Cevap
Filtre ölçütü:
En Yararlı Yanıt
Bu yanıt yardımcı oldu mu?
Puan 1
1 Yorum:
You beat me to the punch! Glad you got it figured out.
tarafından
Yorum Ekle
Based on your previous comment. I would wager the disk hasn't been initialized. It's something I have seen commonly with new drives because they leave them that way so you can format it the way you want.
Check to see if it's visible in Disk Management. In Windows 10/11 you can see that by right clicking on the Start button (or pressing Win + X).
Once you Disk Management you'll get a visual of what physical storage devices are connected. My guess is that One of them will show like the below image as "Unallocated." You can right click on the drive and select "New Simple Volume" specify what size and format you want (for Windows you'll most likely want to use NTFS) and it will ask what drive letter you want to assign, though not necessarily in that order.
Resim
Once you get through that, you should be able to see the Volume you created in File Explorer.
Puan 1
Yorum Ekle
Yanıtını ekle
Brenda Gray sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 3
Son 30 gün: 27
Her zaman: 433
