Camera won’t calibrate
Camera won’t calibrate. Keeps saying no objects found, restarts camera & goes back to finish repair.
Bu iyi bir soru mu?
Bu iyi bir soru mu?
Did you use an original part from Apple? As long as you see an preview, when you do the calibration, make sure there are objects within your surrounding. This can be items on your desk or furniture in the room. This proces can be a bit long but just keep turning the phone until is says finished. Hope this helps.
Bu yanıt yardımcı oldu mu?
The camera was purchased on ifixit, when I do the calibration it says Apple part . I’ve made sure there’s objects in view, it doesn’t recognize them & they are large objects. I get the same message over & over. Then it restarts & the same message appears that I need to restart & finish repair . I’ve tried this many times & it just won’t calibrate.
Son 24 Saat: 1
Son 7 gün: 10
Son 30 gün: 33
Her zaman: 66
You probably have a ripped camera flex or some dirt between the connectors. You could try to disconnect the cameras again, clean the connectors with some IPA and reconnect. Be sure to check the flex cables for rips or hard fold lines.
seppebruyland tarafından
Camera was cleaned & checked, not sure I want to go to the trouble of opening it again. Camera works fine just won’t calibrate
Hairstylistroxx tarafından
