Ana içeriğe geç
15 inç ekran boyutuna sahip HP Spectre Dizüstü Bilgisayarlar için destek kılavuzları ve onarım rehberleri.
Replacement of laptop ssd
I want to replace laptop SSD but the screw of sed is worn out. It can't be opened. Suggest what to do.
Bu iyi bir soru mu?
Puan 0
Yorum Ekle
1 Cevap
Filtre ölçütü:
Seçilen Çözüm
For stripped screws there are tools called 'stripped screw extractor' or 'spiral screw extractor' or 'speed out' or 'easy out'. There are a few different forms of the tool but they do the same thing: bite into the metal of the screw so you can unscrew it. They aren't expensive, you can find them on Amazon or other places. Make sure to get a set that has a very small one and you should be able to get the screw out. Then buy a pack of replacement SSD screws (you can also get those on Amazon) and you should be good.
Bu yanıt yardımcı oldu mu?
Puan 0
Yorum Ekle
Yanıtını ekle
MAHENDRA SOLANKI sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 2
Son 30 gün: 6
Her zaman: 184
