Ana içeriğe geç
Released in May 2020, the 13" MacBook Pro features quad-core Intel 8th generation Core i5 and i7 processors, and Intel Iris Plus 645 integrated graphics. (Model A2289/EMC3456 with two Thunderbolt 3 ports)
MacBook Pro 13" A2289 main display flickering constantly.
Video attached via imgur: https://imgur.com/a/8NkNNMJ
Here's the panic log
Hello,
My Macbook Pro built-in display is flickering constantly as seen in the attached video. Not really sure what is happening. The macbook also shuts itself off after some time not even under any load, just idling, but the CPU gets really hot. And after the restart, it gave me that panic log.
Would the flickering solved by replacing the display? And what's causing that panic log?
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 0
3 Yorum:
Sorry you video is messed up so we can’t see what you are encountering. Can you try posting it again.
tarafından
@danj sorry, something was up with uploading video. Had to post it via imgur.
tarafından
@nhathoangmai - can you output the crash report to a file, as the memory block might help in ID’ing what failed. Clearly the report is telling us the Core 0 thread failed. The video implies the graphics buffer is winking out. It this model the main memory is used so is a RAM chip failing? Or something else.
what do you see when you use an external monitor? That might help like a TV (lower res than the internal).
tarafından
Yorum Ekle
1 Cevap
Filtre ölçütü:
disconnect the touch bar and test it again
Bu yanıt yardımcı oldu mu?
Puan 0
Yorum Ekle
Yanıtını ekle
Harry M sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 14
Her zaman: 42
