Ana içeriğe geç
Repair, disassembly, and troubleshooting information for the Xbox Series X, Microsoft's 4K gaming console. The Xbox Series X was released alongside its companion console, the Xbox Series S, on November 10th, 2020.
Xbox Series X PSU Compatibility 12 vs 14 digit serial
I need to replace the PSU in my Xbox Series X the 2020 release (12 digit SN), it looks like the latest XBX 2024 revision (14 digit SN) has a new Genuine PSU model compared to the 1920 model, are these two compatible with each other?
Newest revision: Microsoft Xbox Series X Disk Drive Model 1882 (14 digit serial number) Power Supply - Genuine
Older revision: Xbox Series X Power Supply
Replace a power supply module compatible with the Xbox Series X video game console model RRT-00010 and RRT-00013. Fix issues like a malfunctioning or burned out power supply. Görseli
Ürün
$69.99
Replace a power supply module compatible with Xbox Series X Disk Drive model 1882 14 digit serial number gaming consoles. Fix issues like a malfunctioning or burned out power supply. Görseli
Ürün
$144.99
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 2
Yorum Ekle
1 Cevap
Filtre ölçütü:
En Yararlı Yanıt
Hi Kevin!
Nope, they are not (If I need to believe Microsoft). You need the correct model to let it work. So, please check what model came out yours and then order the correct model you need.
Bu yanıt yardımcı oldu mu?
Puan 1
2 Yorum:
I installed it and seems to be working fine for the past week. Not sure if it's officially supported but unofficially seems to work fine
tarafından
Ah, good to hear that it does work! Officially, it shouldn't, but glad that it is running without issues so far! Will update on this.
tarafından
Yorum Ekle
Yanıtını ekle
Kevin Stichter sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 6
Son 30 gün: 44
Her zaman: 404
