Ana içeriğe geç
Released in November 2020, the 13" MacBook Pro features Apple's Arm-based M1 SoC with both an 8-core CPU and 8-core GPU. (Model A2338 / EMC 3578 with two Thunderbolt 3 ports)
Battery not detected - cable snapped in half
Hi all. Bought a new battery for a MacBook Pro that I got as faulty - it works great without the battery. Thought a new battery will get it back to normal, but seems like I found why it is not detected - this cable is seemingly snapped.
There is no continuity between plus pin and any other parts on the motherboard. And it feels really loose - absolutely not the way it should be.
Also there is no 12V on the pins when laptop is on but there used to be.
Seems like it is possible to replace it with hot air - is that so?
What is the name of that part? Can it be purchased?
UPDATE:
So of course I soldered a replacement nicely and it works, but MacBook still won’t detect battery data. It won’t start on the battery, but if I start it with power plugged in and then remove it - it keeps on working from the battery.
However it won’t show any battery data or charge level.
Also I noticed that this chip on the flex cable is getting hot to around 50º C when Mac works. Checked nearby caps - no short. Maybe normal, but who knows.
Any idea what it does?
One more thing: trackpad is disconnected can this fact somehow influence battery operation?
And in general any good ideas are greatly appreciated 🙌🏻.
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 0
5 Yorum:
There shouldn’t be any heat that implies there is a short some where.
tarafından
I checked on those caps - 5V and no short
tarafından
And as for Coconut Battery - it also doesn’t detect any battery at all
tarafından
@insympathy - Then I suspect the MacBook Pro 13" Retina (A1708, A2159, A2338) Battery Daughter Board Cable is either not matting fully or is bad.
tarafından
@danj yeah, thanks, gonna buy a new one and see. Seems like either it’s the cable or some mysterious relation to trackpad not being plugged in. We'll see.
tarafından
Yorum Ekle
2 Cevap
Filtre ölçütü:
Ouch! Not good 😡
Sadly this is not offered as a spare part. The only solution which I had to do is salvage the part from a junker board. Over bending the clip is the issue, Apple did a terrible design here.
Bu yanıt yardımcı oldu mu?
Puan 0
9 Yorum:
True, because surely no one has been fooling around with it for any significant amount of time. It was only disconnected a couple of times reeeeeally gently. By me. It was also at some local repair shop - maybe that’s a whole different story, but anyways I’ll have to try to salvage it somewhere. Maybe I’ll try to solder a wire from a connector to the nearby pin where we have 12V with a plugged in power and see if that will work. Then it’ll make sense to replace this connector. If not - maybe I’ll just sell it for parts.
tarafından
@insympathy - These are main power lines which is high current, the gage of the wire needed is quite large.
Just be careful as a short can both create sparks as well as cause the battery to run wild overheating quite quickly if it’s a full short or not.
tarafından
I found this part for purchase, so I'll just replace it
tarafından
@insympathy - Where did you find it I could use a few to fix a few systems.
tarafından
@danj found it here in Kyiv, but try eBay - found it in the US there as well for like 13$ each.
tarafından
4 tane daha yorum göster
Yorum Ekle
It can be found as 821-00583-A
Puan 0
Yorum Ekle
Yanıtını ekle
in_sympathy sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 5
Son 30 gün: 45
Her zaman: 262
