Ana içeriğe geç
Repair guides, support, and troubleshooting information for the first year of the 15-inch MacBook Air, featuring Apple's M2 SoC. Released on June 13th, 2023 and identified by model number A2941.
Replacing the display on a MacBook Air M2 15" (A2941)
The display on my MBA 2023 has failed and I'm looking to replace it myself as I no longer have warranty coverage. If I swapped the display with an unofficial replacement would the new display work properly (no shadow artifacts, etc.)? Or will I need to replace the lid angle sensor and have that calibrated as well? I've looked in past questions on this forum and asked the Genius bar but I'm getting conflicting info. Any advice from those who've tried swapping displays on this model before would be greatly appreciated.
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 0
Yorum Ekle
2 Cevap
Filtre ölçütü:
En Yararlı Yanıt
Different series have different issues, so it’s important to stay focused on what you have for a system. The display technology of the MacBook Pro’s was changed to a mini LED zoned backlight in 2018 which is often what people see and talk about when replacing the display as there is an additional step needed to calibrate the display so the LCD panel and the backlight are in sync.
The source of the display then becomes the issue as Apple didn’t allow the display makers access to the needed firmware to make the display fully work. This is related to both TrueTone and the FaceTime camera so a display that fell off the back of a truck on the way to Foxconn to be assembled with the rest of the system won’t have the needed firmware. Here a used display will allow the camera to to be workable but TrueTone won’t be active as again Apple requires a calibration step.
So then your question is how does one Calibrate the display, this requires getting the display from you guessed it Apple! As the tool is still currently held behind a paywall.
Hopefully that helps explain why you were getting different answers, So let’s now start talking about Your System!
You have two options getting the display from Apples self repair portal or getting a used display. Getting the part from Apple gets you access to the Calibration Tool, the used display will allow the camera to work but you loose TrueTone.
Here’s iFixit guide MacBook Air 15" 2023 ekran değişimi
Here’s one source for a used display MacBook Air 15" Mid 2023, M2 Family Displays presently they don’t appear to have the part, I would ping them directly with a request.
Here’s the Apple self repair site Apple Self Repair sadly not all regions have access.
Here’s the Apple repair manual for your system MacBook Air (15-inch, M2, 2023) and lastly here’s the parts breakdown page to select the part/s you need Parts listing
Bu yanıt yardımcı oldu mu?
Puan 1
Yorum Ekle
You should try to avoid getting 3rd party displays since they tend to not be as high quality which can result in issues such as reduced sharpness. So if possible try to go for an official Apple display if you can find one.
As for the lid angle sensor, I don't think you will need to replace it if you were to perform such a replacement. However, you would most definitely need to calibrate it.
Puan 0
Yorum Ekle
Yanıtını ekle
Derrick Shawn Sutanto sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 8
Son 7 gün: 46
Son 30 gün: 210
Her zaman: 3,125
