Ana içeriğe geç
HP ProBook 450 G1, iş kullanımı için tasarlanmış 15,6 inçlik giriş seviyesi, dokunmatik ekranlı bir dizüstü bilgisayardır. 5 Ekim 2013 tarihinde HP tarafından ProBook serisinin bir parçası olarak piyasaya sürülmüştür.
How to replace the hard drive?
I wanted to play on my laptop, but the laptop says bootdevice not found error. I found a solution, but I don't know how to do this.
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 1
Yorum Ekle
2 Cevap
Filtre ölçütü:
Depends on cause of the failure.
Try booting and hitting F2 to get into diagnostics, check drive.
If there was a Windows update that included a BIOS update - this may have reset BIOS options such as UEFI - try booting to BIOS by hitting F10, and see if boot options are UEFI or Legacy - if UEFI, try changing to legacy - save and restart - if it boots ok that was the issue.
That model came with a HDD or SSD or possibly a HDD/SSD hybrid drive.
Hybrid drive - depends on which part failed. If it was the SSD then you may be able to remove it and see if laptop works without it, as data would be on the HDD. If not, HDD may have failed.
If drive has failed and you want to retain data vs a fresh install? Retain data, clone to new 2.5" SSD of same or larger capacity - I usually do this in another machine where I can connect the old and new drives and clone using clone software. If fresh install - create Windows USB installer, install new drive and boot (F9) to the Windows USB.
Bu yanıt yardımcı oldu mu?
Puan 0
Yorum Ekle
IS IT POSSIBLE TO REPLACE HDD by SDD In 450 G1 hp probbok laptop
Puan 0
Yorum Ekle
Yanıtını ekle
Adi Bašić sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 3
Son 30 gün: 37
Her zaman: 522
