Ana içeriğe geç
Nisan 2003 New York Uluslararası Otomobil Fuarı'nda tanıtılan ve 2004 ABD model yılı için tamamen yeniden tasarlanan Prius, Corolla ve Camry arasında bir boyuta sahip, orta ölçekli bir liftback (arka camla birlikte açılan bagaj kapağına sahip model) haline getirildi. Yeniden dağıtılan mekanik aksamı ve iç hacmi sayesinde arka koltuk diz mesafesi ve bagaj alanı önemli ölçüde artırıldı.
ABS light has problems
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan -1
Yorum Ekle
1 Cevap
Filtre ölçütü:
En Yararlı Yanıt
Herold, as bill was trying to say in his own inimitable way, you have't given us enough information to figure out what's wrong with your car, let alone come up with a fix.
What do you mean when you say the ABS light has problems? Are you just saying the ABS light is on? Or do you mean the ABS bulb is out? As you can see, with only the four words you said, we can't possibly know what the problem is.
If the light is on, you will need to get the ABS system scanned with a reader that can access it; a standard OBD-II reader won't be able to, so as much as I hate to, I would suggest going to a mechanic for a diagnosis. Wheel speed sensors are a common problem with ABS systems, but certainly not the only one possible, so a scan is essential for the proper diagnosis.
Update (01/23/25)
I might add that this is something that is important for you to do, being a safety feature of the car. Your Anti-Lock Braking system will not function as long as the light is on, and if your car is equipped with traction control, that will be disabled as well.
Bu yanıt yardımcı oldu mu?
Puan 1
Yorum Ekle
Yanıtını ekle
Herold Pierre sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 3
Son 30 gün: 10
Her zaman: 181
