Ana içeriğe geç
Released by Motorola in July 2020, the Moto G 5G features 5G technology and four cameras in a budget phone.
Replace front screen on Motorola Moto G 5G Plus phone
Hello
I am a new member from Gothenburg in Sweden. I have a Motorola Moto G 5G Plus phone. Unfortunately I have dropped the phone on the ground and now the front screen is cracked. Is it difficult to replace? How do I do it?
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 1
Yorum Ekle
1 Cevap
Filtre ölçütü:
En Yararlı Yanıt
Hi Mathias,
Welcome to iFixit! It looks like jayeff has helped out editing your question, and I updated the device category for you.
With a broken screen you will want a screen replacement guide; unfortunately iFixit doesn't have a guide for your specific phone, but I did locate one on the Spanish site Nadie Me Llama Gallina that has just what you need.
Manuales / Motorola Moto G 5G Plus / Fullscreen - Nadie Me Llama Gallina
Your phone is similar to a lot of Android phones in that there are two ways to do a screen replacement. The recommended procedure is to replace the screen and midframe as a single assembly; that's the method used in the guide I linked to. This procedure basically involves gutting all of the components of the phone and moving them to a new chassis. That's not really as bad of a job as it sounds, as these phones are designed to make it straight-forward. For someone new to phone repairs, this is the best choice.
The other way to do the replacement is to separate the screen from the midframe and replace only the LCD. There are less parts to remove, but that's offset by having to get the screen off, followed by cleaning the old adhesive off the midframe. The procedure for this type of repair is completely different from the guide so you would have to locate one for yourself; I'd suggest searching YouTube as that's where I've had the most luck locating that kind of information.
Buying the screen with the midframe is usually only a few dollars more than getting one without, but that tends to be offset by the need to buy glue to hold the replacement screen in place, so tends to be about the same cost. Just be sure to verify which one you're getting - with or without the midframe - when ordering, depending on which method you want to take on, especially since some sites sell both.
Use a magnetic sheet to set the screws and parts on so you can keep them in order and be sure to put them back where they came from. It's usually not as much of a problem on phones like the Motorola, but on iPhones you can literally kill the phone by putting the wrong screw in the wrong hole.
Take your time and follow the instructions step by step and you'll do great! Of course, should you run into problems or have questions, there are a lot of very smart people on this site who are happy to help, so feel free to ask questions or advice.
Bu yanıt yardımcı oldu mu?
Puan 2
1 Yorum:
Hi @mathiasnil68459
Just to add when looking for a replacement screen to ensure that you're getting the correct replacement part, search for "Motorola (insert phone model number) LCD screen" and not just "Motorola G 5G Plus LCD screen" as there have been a couple of models released since 2020
tarafından
Yorum Ekle
Yanıtını ekle
Mathias Nilsson sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 16
Son 30 gün: 60
Her zaman: 116
