Ana içeriğe geç
Samsung Galaxy Note20 Ultra Android akıllı telefon için onarım ve söküm bilgileri. Ağustos 2020'de piyasaya sürüldü.
Why won't my Note 20 Ultra get service?
My phone(N20U Exynos) isn't receiving a signal, so no calls/SMS/Data or even Emergency. According to *#0011#, it's telling me that 2 parts have gotten bad.⏎ but I have no idea what these 2 parts are, and idk where they are(remember, I am on Exynos and my motherboard parts are different than the iFixit teardown of the N20U)
Resim
Bu iyi bir soru mu?
Puan 0
2 Yorum
Hi @damaj301damaj
What is the model number of your phone e.g. sm-N985?
Is the phone locked or unlocked?
If unlocked can you try using a different known working compatible SIM card to check if there's a signal?
Has the phone been dropped or gotten wet at all?
tarafından
Hi @jayeff, my phone is an SM-N985F/DS.
Phone is unlocked and works with all carriers, I tried 3 simcards that are known working but they didn't work.
no the phone wasn't dropped nor it got wet, I had service, now suddenly out of service
tarafından
Yorum Ekle
1 Cevap
Filtre ölçütü:
Seçilen Çözüm
Hi @damaj301damaj
Can you charge the phone OK using a USB-C charger?
Also try using the voice recorder app (record in stereo) just to see if that works.
Trying to prove if the problem is related to the charge port board e.g. loose flex cable connection, as some of the antennas for the phone are located on this board
If the above work OK then it may be a systemboard problem. Here's the SM N985F Service Manual that may help.
Go to p.38 (of 55 pdf) to view the GSM, WCDMA, LTE troubleshooting flowcharts and check if it leads to where the problem may be.
There are board layout diagrams on p.2→p.5. Use the search function in your browser to find the location on the board(s) of the components mentioned in the flowchart. You have to zoom in a lot to see them.
Bu yanıt yardımcı oldu mu?
Puan 1
1 Yorum:
Yep, I can record using the voice recording app(both mics) work, and the USB-C charging/USB connection with PC/AA works perfectly, ama check the document you sent and see what to do
tarafından
Yorum Ekle
Yanıtını ekle
Mohamad Damaj sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 6
Son 30 gün: 45
Her zaman: 849
