How to replace the charging port on iPod?
the little open where you stick your charger in one of the little stick things inside of it broke like its up its not down anymore how can i fix that part?
Bu iyi bir soru mu?
Bu iyi bir soru mu?
victoriax, you can try an bend the pin back into position, but you must use a good magnifying source and some very fine tools. I use some dental tools for that. Sometimes you can try and do it with a quilter's needle. If you can not straighten it out, or if it is broken off, you can try and replace the dock connector. It will require you to de-solder and re-solder a small part with even smaller connections, and there are 30 of them. Hope this helps, good luck.
Bu yanıt yardımcı oldu mu?
Son 24 Saat: 0
Son 7 gün: 1
Son 30 gün: 2
Her zaman: 2,409
1 Yorum
Which generation Nano is it?
oldturkey03 tarafından
