Ana içeriğe geç
2.2 GHz (Turbo Boost up to 3.4 GHz), 2.5 GHz (Turbo Boost up to 3.7 GHz), or 2.8 GHz (Turbo Boost up to 4.0 GHz) quad-core Intel Core i7 processor with 6 MB shared L3 cache and an optional AMD Radeon R9 M370X dGPU.
Is Battery Model: A1494 compatible with 15Inch Mid 2015 MacBook Pro?
Hi all,
Is this Model: A1494 compatible with 15 inch Macbook Pro Mid 2015? cna someone help me out here?
Thank you.
Bu iyi bir soru mu?
Puan 0
Yorum Ekle
1 Cevap
Filtre ölçütü:
Seçilen Çözüm
The A1494 battery is used in the A1398 Late 2013-2014 system MacBook Pro 15" Retina (Late 2013-Mid 2014) Battery
Your system requires the A1618 battery MacBook Pro 15" Retina (Mid 2015) Battery
They are physically different in there size, your system needs the smaller battery.
Replace a 8700 mAh battery compatible with MacBook Pro 15" Retina (Late 2013/Mid 2014). 98 Watt Hours (Wh), 11.26 Volts (V). Görseli
Ürün
$89.99
Replace a 8800 mAh battery compatible with a MacBook Pro 15" Retina (Mid 2015). 99 Watt Hours (Wh), 11.26 Volts (V.) Görseli
Ürün
$109.99
Bu yanıt yardımcı oldu mu?
Puan 1
1 Yorum:
Thank you so much for clarifying this :)
tarafından
Yorum Ekle
Yanıtını ekle
Itsmeapple sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 5
Her zaman: 38
