Ana içeriğe geç
Cuisinart kahve makineleri için rehberler ve onarım bilgileri.
Level indicator float loose
The float that indicates coffee level is not working and may have come unattached. It is loose and moves freely when I checked
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 0
Yorum Ekle
1 Cevap
Filtre ölçütü:
I had this problem. I managed to disassemble the reservoir to inspect the float mechanism only to find that the mechanism, being quite flimsy, had been broken, probably by my rough attempts to clean the area by sticking a sponge in the gap inside the reservoir. If you want to take the thing apart, turn the reservoir upside down. There are two Phillips head screws at the bottom of those two holes in the bottom of the reservoir. Once you get them out, turn the reservoir over (right side up) and find the plastic 'clips' under the rim of the reservoir and gently pry the top of the reservoir loose from the main body. You should have access to the float mechanism at this point. Mine was unfixable so I bought a new reservoir from Cuisinart for $35. Love the coffeemaker! Here's a link:
https://www.cuisinart.com/coffee-on-dema...
Good luck!
Bu yanıt yardımcı oldu mu?
Puan 0
Yorum Ekle
Yanıtını ekle
J Mitch sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 8
Son 30 gün: 44
Her zaman: 1,109
