Ana içeriğe geç
PC will not boot up
I hit the power button, fans turn a few times but won't start up. Sometimes the RGB lights turn on but nothing else.
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 0
1 Yorum:
Hi @zombieslay72601
What is the make and model number of the PC or motherboard if it is a custom build?
tarafından
Yorum Ekle
3 Cevap
Filtre ölçütü:
It’s sounding like your PC is having a power issue. Here are a few troubleshooting steps to attempt:
Check the Power Supply (PSU)
Make sure that the power cable plugged into the wall outlet and into the PSU is firmly in place.
Use an alternate power cable or wall outlet.
If you have a PSU switch (I/O) turn it off and on.
If possible test with another PSU.
Check for a Short Circuit
Turn off and disconnect everything.
Open your case
Bu yanıt yardımcı oldu mu?
Puan 0
Yorum Ekle
Well you can try the following:
  1. Try a different power source.
  2. Check your monitor connection.
  3. Disconnect your devices.
  4. Listen for beeps if any coming.
  5. Start your PC in safe mode.
  6. Restore your computer to previous settings. .
  7. Check for unresponsive apps.
  8. Unplug USB devices.
Puan 0
Yorum Ekle
Your PC may have a power supply, motherboard, or RAM issue. Try these steps:
  1. Check power cables and connections.
  2. Test with a different power outlet.
  3. Reseat RAM and GPU.
  4. Clear CMOS by removing the battery.
  5. Test with another PSU if possible.
Puan 0
Yorum Ekle
Yanıtını ekle
Zombie Slayer sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 5
Son 30 gün: 10
Her zaman: 225
