How can I fix on a epson pro styles 4880 printer
service req. 0001001d
Bu iyi bir soru mu?
@rosarioalcocer service code is 0001001D means Scale CR servo parameter error. Check/try these things:
Your printers CR Motor has too heavy a load on it, check:
The CR Encoder Sensor and the CR Scale must be free from dust and dirt or any other foreign matters.
Execute encoder checking by the "Maintenance Mode 2".
The CR Timing Belt must be free from any defects and the belt must be in proper tension.
The Carriage Unit must slide smoothly, free from undue load.
Measure the resistance value of the CR Motor. (19.3 ± 10% [Ω]) If the CR Motor is found in short mode, replace the BOARD ASSY., MAIN at the same time.
All the harness must be connected properly and free from short circuit or broken wire.
Remedy
1. Check for dirt, paper dust or damage to the CR Scale
2. Perform the CR Timing Belt Tension Adjustment
3. Replace the CR Encoder Sensor
4. Replace the Motor Assy., CR
5. Replace the C593 MAIN Board
For the remedies, go through the individual checks and replacements shown on page 185 of the EPSON Stylus Pro 4400 4450 4800 4880 4880C SM
Bu yanıt yardımcı oldu mu?
Son 24 Saat: 2
Son 7 gün: 7
Son 30 gün: 24
Her zaman: 44
Hey @rosarioalcocer! This appears to be a servo parameter error as indicated in this site:
https://epson.com/faq/SPT_C593001UCM~faq...
I would try taking a look at that and the carriage. Some more information on how this occurred would be helpful in determining a solution
Josh Yacktman tarafından
