Ana içeriğe geç
Kasım 2020'de piyasaya sürülen PS5 konsolu, büyük ölçüde geliştirilmiş görseller ve yenilikçi yeni bir DualSense oyun kolu sunuyor. Uzay çağına uygun siyah-beyaz renk düzeni, geçmişteki PlayStation tasarımlarından belirgin bir kopuşu temsil ediyor.
PS5 Disc Drive Failure
My PS5 (model CFI-1115A) is no longer reading any discs. It takes the disc in, sounds like it's starting to read it, but then it stops. There's an error on the screen that the discs are unreadable. I am assuming this is most likely a laser issue, given that discs insert, spin, and eject just fine. I see that there are replacement lasers available on eBay, as well as replacement drives. Are the lasers compatible with all models, or are there differences between the models? Am I better off getting a full replacement drive, and transferring the daughterboard over?
Bu iyi bir soru mu?
Puan 3
1 Yorum
Your diagnosis is spot on—since mechanical feed and ejection work fine, the laser lens (KES-497A) is failing. While PS5 lasers are standardized across all original fat models (CFI-10xx through 12xx), replacing just the lens requires delicate ribbon handling and precise alignment. You are much better off buying a full drive assembly and swapping your original daughterboard onto it, as the drive board is cryptographically paired to your motherboard. Swapping the board saves tedious micro-assembly and guarantees your console will read discs again. If you'd rather not open the drive, local console repair specialists (like F2 Technology in the UAE) can handle the daughterboard swap for you.
tarafından Paylaş
Yorum Ekle
2 Cevap
Filtre ölçütü:
Seçilen Çözüm
Hi There!
It does sound like the laser is failing.
I recommend to replace the whole laser deck! So not the drive or the laser only. But just the laser deck.
There are more models available for the PS5. The most easiest thing to do, is to open up your PS5 and get the drive out. Check the model and order the one you need!
Then you are sure that you do have the right one.
And otherwise, you can always share some pictures with us :)!
Good luck!
Bu yanıt yardımcı oldu mu?
Puan 2
8 Yorum:
I finally had a chance to open it up. I don't see any model on the drive, but the drive logic board has a UHN-020 model number.
tarafından Paylaş
Upon further testing, the drive will only read DVDs. I assume this means that the Blu-ray laser is failing?
tarafından Paylaş
That most of the time means that the PCB isn’t transfered from the old drive. Did you do this? If yes, please check the blu-ray pot meter.
tarafından Paylaş
I haven't replaced the drive. The stock disc drive is the one that will only read DVDs. It's still in my PS5.
tarafından Paylaş
Is the laser deck different for certain models of the PS5? Or will it be compatible with any model?
tarafından Paylaş
3 tane daha yorum göster
Yorum Ekle
Puan 0
Yorum Ekle
Yanıtını ekle
timepants sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 10
Son 7 gün: 59
Son 30 gün: 239
Her zaman: 3,028
