Ana içeriğe geç
Model Number A1707. Released June 2017, this MacBook Pro features Kaby Lake processors up to the 2.8 GHz quad-core Intel Core i7 processor with Turbo Boost up to 3.8 GHz.
Low cycle count, needs service
Hello all, I am new to the forums so thank you in advance for any help, and my apologies if I sound naive. My second-hand MacBook, has 129 charge cycles on it but it dies super fast and it requires service. It is the OEM battery but from what I am told it wasn't used much. Is there anything I can do aside from replacing the battery? Change charging habits? By that Charge between 50-80% let it die, charge fully, and keep it around that 50-80% mark and let it fully charge and die periodically? My thought is that I may "reactivate" the cells by doing that given its low usage. Any input is much appreciated and even experimental ideas are welcome as in the end, i expect to be doing a battery replacement. Thanks!
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 0
Yorum Ekle
1 Cevap
Filtre ölçütü:
Everyone will likely recommend that you install CoconutBattery and post to your question the report it will give, we can then see what charge capacity is remaining in the battery. Service notification is usually the beginning of the end for a battery.
Bu yanıt yardımcı oldu mu?
Puan 0
1 Yorum:
You only need the trial version, but it’s a great tool to have to monitor things
tarafından
Yorum Ekle
Yanıtını ekle
Robert Warnock sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 1
Son 30 gün: 18
Her zaman: 42
