beep, no power repair
Hello,
I am repairing some PS5 console with common beep - no power issue. I quickly measured common locations for shorts and I think I found one, but I'm not really sure if it's a short or is intended behaviour. It's near Dialog DA9081 power management chip, where an inductor (at least I think it is) is connected from what it looks like to me a common connection of pins 21, 22, 23 and 24 - although I find this very strange, as 21 and 22 are analog inputs, 24 is positive voltage terminal and 23 is analog ground. The other side of this inductor is shorted to ground, but there are clearly some capacitors so I think there should not be a short. Before I remove the chip I would like to hear your opinion.
I removed this what I think was inductor and took a shot with my microscope. Rectangle is where inductor was and I marked the X spot where I'm measuring against ground. I must say that short is only measured if I put positive probe to X and negative to ground. If I reverse it, I don't get a short.
BTw, anyone would know what value is this inductor so I can replace it once I find a defect?
Thanks
Bu iyi bir soru mu?
