Ana içeriğe geç
Repair guides and support for Canon's EOS Rebel XSi. This is a DSLR camera with a 12.2 MP sensor released in 2008. Also known as the EOS 450D and the EOS Kiss X2.
Why does my screen flicker like this after about 10 seconds?
Why does my screen go like this about 10 seconds after turning it in, and then soon after the camera shuts down and sometimes gives an err99? Thanks
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 0
2 Yorum
Hi @inglewood
Check if the procedures shown in this video will fix the problem or not.
tarafından
Thanks. Done all that. After “rebooting” the camera, same thing happens. Every time.
tarafından
Yorum Ekle
1 Cevap
Filtre ölçütü:
En Yararlı Yanıt
@inglewood the err99 is a very generic error code. It can show up when there is a lens incompatibility, a battery problem, a shutter problem or bad contact between the body and the lens. I don't think it is related to your LCD issue. That actually looks like a bad LCD display. It will start to get double vision when it warms up. I suggest you consider replacing the display and while you work on your camera, make sure that the ribbon cable and connectors are not bend or corroded. Canon EOS Rebel XSi LCD Screen Replacement
Bu yanıt yardımcı oldu mu?
Puan 1
2 Yorum:
Thanks OldTurkey. I ‘ve ordered the lcd. I noticed that the flex cable joining the power board to the main motherboard has two black (maybe burnt) places where it goes into the plug on the motherboard. Doesn’t look good.
tarafından
@inglewood hopefully its just the LCD and not the connector or even worse. Anyhow, keeping my fingers crossed that a new lcd will fix this.
tarafından
Yorum Ekle
Yanıtını ekle
Inglewood sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 5
Son 30 gün: 16
Her zaman: 41
