Ana içeriğe geç
Model No. A1367 / 8, 16, 32, or 64 GB capacity
915 Soru Tümünü görüntüle
Soru Kapandı
How to enable my iPhone?
my iphone 4 is disabled for 21,640,944 any ways of getting into it :(
Bu iyi bir soru mu?
Puan 0
1 Yorum
Is it an iPhone or an iPod?
tarafından
Yorum Ekle
1 Cevap
Filtre ölçütü:
Seçilen Çözüm
joshua, one thing that should work for you is to just connect it to iTunes. iTunes will unlock it for you and you don't have to restore, power off, or anything. Just make sure that you use the computer that your normally use to sync with. The other thing you can try if the first step don't work, is to place the iPod/iPhone in DFU mode and then connect to your computer and restore via iTunes. Connect it to your computer and put it into DFU mode, and then restore it to the latest firmware. You can enter DFU mode by following these steps: 1.) Make sure your iPod Touch is turned on and connected to your computer. 2.) Hold the home and power buttons down at the same time for exactly 10 seconds. 3.) After 10 seconds, release the power button and keep holding the home button for as long as it takes before your computer recognizes your iPod Touch. From here, you need to restore it, by simply clicking restore and it will wipe your iPod of all previous settings and put the firmware back on. Hope this helps, good luck.
Bu yanıt yardımcı oldu mu?
Puan 1
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 0
Her zaman: 471
