Why is my computer not charging
My computer is not charging and cannot switch on
Bu iyi bir soru mu?
Bu iyi bir soru mu?
@raggahtwin "not charging" and "cannot switch on" are two different things. A computer that does not turn on will be a greater issue then one that does not charge. You have not told us what you have tried.
Start off with the easy things. Disconnect the power from the computer by unplugging the power cord from your computer. Disconnect all external devices from the computer. Now hold the power button depressed for about 30sec-1min. Reapply the AC power adapter and see if your computer does show any sign of life.
Next you want to check your power supply. Make sure it has the proper voltages. Check to make sure that connectors are not bend etc. Check the DC-in jack of your laptop. Make sure there is no corrosion, debris etc. that prevents it from working. Clean it of any debris etc, use a few puffs of air to clean it out. If none of this works, get a ammeter and see if your laptop draws any amperage from the charger. After that, you need to check and see if your motherboard even gets power. For that of course, you need to open it up. Post Some good pictures of what you see. That way we can see what you see. Mevcut bir soruya görsel ekleme
Of course, you may also have to consider replacing the battery. A depleted battery can no longer be charged. However, it should not prevent your computer from coming on, if it is connected to the AC adapter.
Use the HP 2000 Maintenance And Service Guide to work on your computer. Let us know what you find out.
Bu yanıt yardımcı oldu mu?
Son 24 Saat: 0
Son 7 gün: 2
Son 30 gün: 12
Her zaman: 178
