Ana içeriğe geç
Xbox One controller was introduced in 2016 with the launch of the Xbox One S and adds Bluetooth support for Windows 10/11. This controller fixes many of the design flaws found on the Model 1537/1697 controllers and is much more reliable. This controller has been replaced with the improved Model 1914 controller.
Xbox says controller is disconnected
My Xbox continually says that my controller is disconnecting, even though the light on the controller is still on. I’ve used 3 controller, multiple batteries. I’ve used the USB port in the xbox to charge the controller and it still happens. I’m not exactly sure if this is an Xbox issue or a controller problem. I ordered a new xbox controller and its currently on the way so maybe that will fix it. But any idea will be greatly appreciated. Thank you.
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 1
Yorum Ekle
1 Cevap
Filtre ölçütü:
Can you confirm if you are connecting this to an xbox console or PC please?
Also, can you confirm if what you are using to connect the controller, is it always wireless or do you ever use a USB type cable?
Also, are you using battery packs, as in a pre-made after market battery rather that the traditional AA size standard batteries?
Thanks in advance for your answers :)
Bu yanıt yardımcı oldu mu?
Puan 0
1 Yorum:
It is an Xbox one console. It is a wireless controller but i have used the USB port in the console to charge the controller and still no luck. I mainly use battery packs but even with the issue I’ve been having it happens even when I’m using packs or AA batteries. Thank you!
tarafından
Yorum Ekle
Yanıtını ekle
Nathan Tarr sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 1
Son 30 gün: 6
Her zaman: 83
