Ana içeriğe geç
On screen colouring linings
When I on my tv then television have some colouring lines on screen television work but screen not work
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 0
Yorum Ekle
1 Cevap
Filtre ölçütü:
1. Check Cable Connections
  • If you're using an external device (like a set-top box or gaming console), unplug and reconnect the HDMI or AV cables.
  • Try using a different HDMI port or cable to rule out a connection issue.
2. Perform a Power Reset
  • Turn off the TV and unplug it from the power source.
  • Press and hold the power button on the TV (not the remote) for 30 seconds.
  • Wait a few minutes, then plug the TV back in and turn it on.
3. Inspect for Physical Damage
  • If the screen has cracks or pressure marks, the panel may be damaged, requiring replacement.
4. Test the T-Con Board (If You Can Open the TV)
  • If the lines appear consistently across all inputs and the menu, the T-Con board or ribbon cables may be faulty.
  • Try reseating the ribbon cables that connect the display to the motherboard.
5. Contact Support If Needed
  • If none of these steps work, the panel or internal components may need professional repair or replacement.
Let me know if you need more details! 😊
Bu yanıt yardımcı oldu mu?
Puan 0
Yorum Ekle
Yanıtını ekle
Mnopqrs sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 2
Son 30 gün: 8
Her zaman: 140
