Ana içeriğe geç
Slim, lightweight and stylish, the Swift 3 is the ideal laptop for working on the move. The latest NVIDIA® GPU, Intel® CPU and long battery life are housed inside a choice of displays: an elegantly silver chassis with a 13.5” 3:2 ratio 2256x1504 IPS VertiView Display or the vivid colors of a 14” 16:9 FHD IPS display.
My fan is being loud
sometimes when i tilt the computer or kind of bump into it the fan starts to make very loud noises
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 0
Yorum Ekle
1 Cevap
Filtre ölçütü:
It looks like your fan might be loose, misaligned, or have debris inside. Here are a few things you can check:
  1. Loose Fan or Screws – Open the laptop and check if the fan is securely mounted. Tighten any loose screws.
  2. Debris or Dust – Dust buildup can cause imbalance. Clean the fan using compressed air or a soft brush.
  3. Bearing Wear – If the fan's bearings are worn out, it may need replacement.
  4. Cable Obstruction – Check if any internal cables are brushing against the fan when you move the laptop.
  5. Physical Damage – If the fan blades are cracked or bent, replacing the fan is the best option.
If the problem persists, consider replacing the fan to prevent further damage to your system.
Bu yanıt yardımcı oldu mu?
Puan 0
Yorum Ekle
Yanıtını ekle
Matěj sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 4
Son 30 gün: 16
Her zaman: 16
