Ana içeriğe geç
2.2 GHz (3.4 GHz'e kadar Turbo Boost) veya 2.5 GHz (3.7 GHz'e kadar Turbo Boost) dört çekirdekli Intel Core i7 işlemci, 6 MB paylaşımlı L3 önbellek.
Touchpad not found after replacement
Hi all -
Original symptoms were short battery life and touchpad physical clicking not working. I bought a replacement battery and touchpad.
Battery was definitely bulging and putting pressure on the touchpad. I swapped out both and when booted back up - no mouse movement or clicking at all from the touchpad. External mouse works fine, so I went into system preferences and then Touchpad. It said "Touchpad not detected" or something along those lines and had a spinning circle indicating that it was searching for bluetooth touchpads.
So I opened it back up and swapped in the original touchpad - mouse movement but no clicking. But still, system preferences says it doesn't detect a touchpad (I was hoping to at least turn on tap to click.)
So, what am I missing? Is there some extra step to set up the touchpad with the OS? Does the lack of movement on the replacement pad mean that it's DOA?
Thanks for any help!
Bu iyi bir soru mu?
Puan 1
Yorum Ekle
2 Cevap
Filtre ölçütü:
Seçilen Çözüm
Did you also replace the trackpad cable with the trackpad MacBook Pro 15" Trackpad Cable (13/14) the cable holds the interface chip which can get damaged.
Bu yanıt yardımcı oldu mu?
Puan 1
4 Yorum:
Yes, the new trackpad came with a new cable. I haven't removed the cable from either pad, just disconnected from the logic board
tarafından Paylaş
@agitatedgopher - Try replacing the cable with a fresh one. I’ve hit a few bad ones as I suspect the chip is a bit static sensitive (ESD).
tarafından Paylaş
Oh, I forgot to come back here, but yes, that fixed it! Went to a mac repair shop, showed them what I needed, the guy in the back who knew everything got me a cable, and I forgot what they charged me for it, but it's working happily now.
tarafından Paylaş
@agitatedgopher - That's Great! Don't forget to score and accept the answer so others find the solution. Thanks!
tarafından Paylaş
Yorum Ekle
En Yararlı Yanıt
Have a look at the MacBook Pro 15" Retina Display Mid 2014 Anakart Değişimi & check step 25 for the touchpad connection to see if it is correctly seated. This maybe your issue.
Puan 1
2 Yorum:
Well, that was the first thing I tried, reseating the connector. Still no change. Then I reinstalled the original pad and got mouse movement, but it still doesn't show up in preferences. Then I switched back to the new pad and it's still no movement and not showing up in preferences
tarafından Paylaş
@agitatedgopher Hmmmm.... Maybe @danj can give some thoughts....
tarafından Paylaş
Yorum Ekle
Yanıtını ekle
AgitatedGopher sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 2
Son 30 gün: 19
Her zaman: 287
