Ana içeriğe geç
The rotating side brush is no longer rotating
I've unscrewed the screw that holds the brush in place, removed the brush, cleaned the area, and reinstalled the brush without success.
Bu iyi bir soru mu?
Puan 0
Yorum Ekle
1 Cevap
Filtre ölçütü:
Seçilen Çözüm
As it appears that you've already taken a few easy steps without success, there is most likely something wrong with the side brush motor assembly.
Luckily an awesome Ifixit contributor has created a guide on replacing it!
it can be found here:iRobot Roomba 630 Side Brush Motor Replacement
while the model number is different it shares the same construction and should still work.
Hope this is helpful!
Bu yanıt yardımcı oldu mu?
Puan 0
2 Yorum:
Thanks! I've ordered a replacement motor. Hopefully that will do it.
tarafından
It worked :)
tarafından
Yorum Ekle
Yanıtını ekle
Carorhoomba sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 6
Son 30 gün: 44
Her zaman: 44
