Panasonic PV-2700-B VCR won't even try to wrap tape around heads
This is an the oldest VCR I have worked on so far being made in 1987. VCR accepts tapes perfectly fine but does not even attempt to wrap the tape around the heads. Both motors are functioning fine and both belts are somehow in working condition. If I try to turn one of the pulleys to manually pull the tape out, I can only get about 5 rotations (which doesn't do much) when the VCR takes over and brings it back to starting position. I am great at fixing mechanical problems on VCR's but this seems to be maybe a sensor issue (if it has sensors, I can't see any) or an issue with the control panel. 2 notes: the VCR takes about 15 minutes to turn on after plugged in, not sure if this is just an old VCR things or what and there seems to be burn marks on both the top and bottom panel, but none of the inner components are burnt and one of these "burn marks" is in the shape of both the belts, which I can't see getting hot enough to burn the case, not sure what it is. Can't see any evidence of leaky capacitors or just exploded ones.
Bu iyi bir soru mu?
