Ana içeriğe geç
Logitech Rumblepad™ 2, 2000'li yılların ortalarında piyasaya sürülen ve titreşim geri bildirimi sağlayan bir PC oyun koludur. 2 adet analog çubuk, dijital bir yön tuşu (d-pad) ve 12 adet dijital tuş içerir.
My buttons are automatically working
button are working automatically by their own and and the right analog stick is also working automatically. Also i cant set any keymapping it automatically fetch keymapping and starts working by its own
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 3
Yorum Ekle
1 Cevap
Filtre ölçütü:
Inspect and clean around the buttons, it can do that if its dirty or if there's a tiny bread particle or something stuck in there, it also could be because the usb plug is falsy (common problem for this controller). Basically when it disconnects and reconnect randomly(because the usb plug's is falsy). the last button u pressed will be stuck there, so if u pushed analog stick "up" for example and then disconnect and reconnect, it will read it as the analog stick is pushed up even tho it's not, in that case, just disconnect and reconnect without touching any button.
if none of this is your problem,Close any keymapping software.
  • Check Steam > Settings > Controller > General Controller Settings, and uncheck options like “Generic Gamepad Configuration Support” temporarily to see if behavior changes.
  • If a keymapping profile is auto-loading, delete or reset it.
Bu yanıt yardımcı oldu mu?
Puan 0
Yorum Ekle
Yanıtını ekle
Different Learning Centre sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 9
Son 30 gün: 40
Her zaman: 473
