Ana içeriğe geç
A range of laptops designed for medium-to-high performance gaming and content creation.
Why cant I reset my laptop
i am not able to reset my laptop.
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 0
4 Yorum:
Yoosaf, can you clarify what you mean by "reset"? Are you saying Ctrl-Alt-Del doesn't work, or the reset button won't restart the computer, or you can't reformat the hard drive, or what? The word reset can have several meanings and we can't guess which one you mean, so please elaborate on what you are trying to do so we can help you figure out how to do it.
tarafından
When i am trying to rest i am getting message no changes were made. There was a problem with resetting your pc. Also sometimes my laptop wont start when it start i get a message from the startup screen that "Alert! Memory error occured"
tarafından
@yoosafmihadad what is the exact model for your laptop and what operating system are you using?
tarafından
I am using dell g15 and windows 11
tarafından
Yorum Ekle
1 Cevap
Filtre ölçütü:
First, that RAM error means one of the modules is generally bad on these - it doesn't surprise me since the OEM Dell RAM on the consumer side is not as good as on the business PCs and even aftermarket RAM. It isn't terrible - it's just not as long-lasting. The OEM RAM on these Dells is problematic ENOUGH you ought to replace both sticks with good RAM from Corsair or retail-packed Crucial RAM (Micron-branded modules are the "OEM" version) when it fails - skip the OEM stuff Dell sells; it's not much better. That said, if you want to try swapping the modules around and running a memory test, use Memtest 86+ to see if it has any errors after running for at least 4-5 hours MINIMUM. These OEM modules from Dell don't always immediately fail out, but they do begin to fail things like memory testing with a few hours of stress. There's a reason when I buy gaming PCs from Dell I buy them with 16GB and buy aftermarket RAM kits to install 32GB; it's cheaper and I've had better luck with aftermarket RAM then the OEM Dell modules.
The "there was a problem resetting your PC" error is a MAJOR red flag - it generally means the recovery files got corrupted at some point, or the machine had a malware infection that corrupted them by design to prevent easy rollbacks. The machine is not in a stable condition. Now you can run SFC /SCANNOW in admin mode, reboot the PC, and undo the corruption. The downside is this generally only works under these conditions:
  • It's not a virus
  • The damage done is easily recoverable (rarely is)
Sadly, your best bet there is to backup the PC, get a copy of your drivers on a USB drive, and reinstall Windows with an image from the Media Creation tool:
Bu yanıt yardımcı oldu mu?
Puan 0
Yorum Ekle
Yanıtını ekle
Yoosaf Mihadad sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 1
Son 30 gün: 43
Her zaman: 43
