Ana içeriğe geç
Repair and disassembly guides for Epson printer. The company was founded in 1942 as Daiwa Kogyo, Ltd., but merged with another company in 1959 to create Suwa Seikosha Co., Ltd.
epson printer won't print color
Hi my Epson Printer ET 2800 won't print color, from few days. Problem come after several several cleaning cycles and I did not want to waste anymore ink. I cleaned the heads by injecting a cleaning solution through the ink feed ports per videos. Black works fine, but none of the 3 color heads will print anything during a nozzle check. No spots, nothing but blank sheet where CYM should be printing. Cables to the head look fine. Any suggested causes or fixes?
Bu iyi bir soru mu?
Puan 2
1 Yorum
I have run the nozzle check several times the black works fine but there is NO color from any of the other three banks. All of my colors are full.
tarafından
Yorum Ekle
1 Cevap
Filtre ölçütü:
Seçilen Çözüm
If you are facing this problem then tried the solutions you are telling then you should try using the new ink cartridges. Plus, check the printing settings are set to color, and perform the power cleaning. Besides that, look for the additional help could also be helpful to fix it easily.
Bu yanıt yardımcı oldu mu?
Puan 0
Yorum Ekle
Yanıtını ekle
Charles Smith sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 15
Son 30 gün: 73
Her zaman: 711
