Ana içeriğe geç
Screen turned off permanently.
Hi Team, the screen for Fitbit Inspire 2 has turned off permanently and not coming back. Although the vibration as well the sensors and the device on/off/restart are working fine from the inside. As the screen is turned off completely i cant even pair it with any other device too. Please help. If there is any facility inside India where i can send my Fitbit Inspire 2 and get the screen replaced. Do let me know.
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 1
1 Yorum:
My mom is having the same problem.
Also, prior to the issue, her screen was extremely dim. To assess the device, I had to take it into a darkened room.
I restarted the device:
1. While connected to a charger, hold down the side buttons for 15 seconds until the smiley face appears.
After restarting, the smiley face was the only content to appear on screen, no watch face appeared. However, just at the OP experienced the device HR sensor lights, and the device gives haptic feedback (vibrates) when buttons are pressed.
tarafından
Yorum Ekle
2 Cevap
Filtre ölçütü:
You should try to contact Fitbit and see if you can get any service done. Also check your local repair shops and see if they can replace your screen.
Bu yanıt yardımcı oldu mu?
Puan 0
Yorum Ekle
I haven't tried yet, because I don't have the device with me, but I read somewhere that you could try using a synchronized device and change the watch face settings. That might cause the display to reset and reappear?
Puan 0
Yorum Ekle
Yanıtını ekle
Tribikram Behera sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 5
Son 30 gün: 37
Her zaman: 319
