One side is not working.
The two bands on the driver's side are not working. All wires are connected and the bands are intact.
Bu iyi bir soru mu?
Bu iyi bir soru mu?
Try swapping the L and R side speaker wires. If the sound switches sides, then you know the headunit/amp is the problem. If the sound stays on the same side, then you know the speakers or speaker wiring is the problem. If you can, run a new speaker wire from the headunit/amp to one of the speakers that's not working. That will help you troubleshoot if there's a wiring problem or a speaker problem. And of course double-check your balance and fader settings first!
Bu yanıt yardımcı oldu mu?
Son 24 Saat: 3
Son 7 gün: 12
Son 30 gün: 35
Her zaman: 394
