Ana içeriğe geç
Apple'ın 11 inç MacBook Air modelinin Mart 2015 güncellemesi, beşinci nesil Intel Core i5 ve i7 işlemcilerle donatılmış olup, performans ve pil kullanım süresinde küçük bir artış sunmaktadır.
Keyboard or trackpad failure (Unit 1)
Previously working fine without any issues and have just been stored for some time unused only to occasionally give some charge to keep battery health.
Clean installation OS 12.7.6 Monterey & new batteries.
No evidence whatsoever of water damage.
Tested with a couple of new touch pad cables.
All keys seems to be working fine QWERTY 123 etc....
Touch pad seems to have all features working.
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 0
2 Yorum:
What is not working? The Trackpad or the Keyboard or both?
Using an external keyboard and mouse go into About This Mac > System Report - Click on Hardware to expand and jump to USB section . Click on the section heading looking for where the Keyboard / Trackpad is listed, click on it and take a snapshot of the lower section expanded out.
tarafından
@danj The internal KB & TP's seems to be functioning OK providing I get a second where the menus aren't popping up and down or flashing (2 units showing very similar symptoms) very weird, immaculate condition insiade and out both.....
tarafından
Yorum Ekle
1 Cevap
Filtre ölçütü:
So you have ghost touch syndrome! This is a trackpad issue when moisture (cleaning liquid) has entered into the membrane sandwich. See if a hair dryer warming up the trackpad fixes things.
Bu yanıt yardımcı oldu mu?
Puan 0
4 Yorum:
I don't have a hair drier but I do have a heat gun...... I will try at say 80 degrees to see if it helps or should I go higher? Internal inspection all looks perfectly well....
tarafından
@livfe - Hopefully lower if it hurts you it’s too hot.
tarafından
@danj I will swap out the track pad and see if that cured it when I have a spare floating around.
tarafından
I finally got back to this and have changed over with 3 track pads and 3 TP cables and it still has this flashing effect. Turned off auto hide the dock and restarted. Tried everything even with another SSD with Monterey on it (Clean Instal) and it still flashes. Great.
tarafından
Yorum Ekle
Yanıtını ekle
livfe sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 2
Son 30 gün: 17
Her zaman: 281
