Ana içeriğe geç
Hollandalı üretici Philips; damla kahve makineleri, tam otomatik kahve makineleri ve SENSEO® marka adı altında tek porsiyonluk kahve makineleri sunmaktadır. Genellikle Saeco veya Gaggia markaları altında da bulunurlar.
Machine not pulling shots
My Phillips ep 4321 is not pulling shot. Water seems to be going into the tray instead of shots. Steam wand works fine
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 1
Yorum Ekle
2 Cevap
Filtre ölçütü:
Did you manage to fix it? Having the same problem after cleaning the machine
Bu yanıt yardımcı oldu mu?
Puan 0
Yorum Ekle
I had the same issue, check the gaskets on the inside of the machine, specifically the brewing unit(looks like a nozzle with one bigger gasket, that narrows down closer to the tip with a smaller gasket). This is where it usually leaks due to a lot of pressure, that can not be held. The water doesn't go into the brew group (the plastic amusement park, mostly black with a few yellow parts) and goes right into the tray, while the milk steamer works. Lubricating the gaskets also seems to be important. The brew group also has a few gaskets, that do deteriorate. Since the machine stopped working properly after the cleaning, I would check the gaskets and lubrication of the brew group as well. Be careful if you are disassemble the brew group, keep track of the position of the spring and glass bead/ball.
Puan 0
Yorum Ekle
Yanıtını ekle
Ron G sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 1
Son 30 gün: 30
Her zaman: 237
