How do I check the transmission fluid in my 2005 Chevrolet Cavalier
My transmission dose not have a dip stick and i need to check the level and do not have the money to go to a repair shop. How do i check it
Bu iyi bir soru mu?
Bu iyi bir soru mu?
Thomas Wahab, this from the ownders manual "It is not necessary to check the transaxle fluid level. A transaxle fluid leak is the only reason for fluid loss. If a leak occurs, take the vehicle to the dealership service department and have it repaired as soon as possible." :-) Anyway, here is what the transmission service manual says:"
Transmission Fluid Checking Procedure:
1. Start the engine and allow the engine to idle until the transmission fluid temperature has reached the value specified.
2. Depress the brake pedal and move the shift lever through the gear ranges, pausing a few seconds in each range. Return the shift lever to the PARK range.
3. Remove the fluid vent cap.
4. Raise the vehicle on a hoist. The vehicle must be level, with the engine running and the shift lever in the PARK range.
5. Remove the transmission oil level control plug (65).
Check the fluid level. Th efuid level should be even with the bottom of the threaded plug hole. If it is low add DEXRON III automatic transmission fluid in increments on 0.5L (0.5qt) until the fluid drains from the plug hole."
Hope this helps, good luck
Bu yanıt yardımcı oldu mu?
There is a 10 mm plug under the car. revove it and if oil comes out its full. You add oil on the top where there is a red or black vent
cap.
Son 24 Saat: 1
Son 7 gün: 17
Son 30 gün: 111
Her zaman: 54,301
5 Yorum
you've got to be $@$*!&%& me! this is the dumbest idea chevy came up with!
tlc08 tarafından
Anything to get more money outta ppl right. Its not like we aint got enough bills n payments to deal with already etc....
If I would have known this I never would of got this truck. N from what I've heard its only Chevrolet... Or am I wrong?
Tanya Goodwin tarafından
Hi do i have the 2004 chevy engine running when i check the fluid level?
Jamie N Ronk tarafından
Why is it not necessary to check your transmission fluids? and why don’t this car have a dip stick and where can I find one for my car?
jeanettaoguin tarafından
Under the car below the transmission is the
davidarnold6770 tarafından
