Ana içeriğe geç
Bu cihaz, Samsung Galaxy S II'nin T-Mobile versiyonudur. Ekim 2011'de piyasaya sürülmüştür. T-Mobile'ın yeni genişletilmiş 4G ağını içeren ilk Galaxy modelidir.
How do I fix a charging issue?
For some context, i found my old Galaxy S2 (SGH-T989) in a box, i tried charging it but when it turned on a white line flashed and it blacked out, and anytime i try charging it, i have to hold pressure on the connector. So please if anyone knows what to do, please help.
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 0
Yorum Ekle
2 Cevap
Filtre ölçütü:
It sounds like an issue with the charging port, assuming you've tried a different cord to verify that it's a problem with the port and not the cord.
Try cleaning the port with, say, some 90% or higher concentration isopropyl (rubbing) alcohol, a toothpick and an eyeglass cloth. You can also attempt to blow it out with compressed air or vacuum it.
So if you're still not having any luck with it, sounds like you would need to replace the charging port. Unfortunately on your phone it's mounted directly on the motherboard, so replacing it would require soldering. You would need moderate soldering skills; it's not quite microsoldering but close. Here's a picture of the bottom side of the motherboard, that the port is mounted on.
Resim
If you're not confident in your soldering skills, this shouldn't be a difficult replacement for a decent repair shop. Of course, you could simply replace the whole motherboard; I saw one on eBay going for about $12 USD, not counting shipping. Here's the guide you'd need to pull the motherboard either for repair or replacement.
Samsung Galaxy S II T989 Motherboard Replacement - iFixit Repair Guide
Bu yanıt yardımcı oldu mu?
Puan 0
Yorum Ekle
I have an idea. First, check the battery. Typically, a battery lasts around 3 to 4 years, so it might have lost its ability to power the device or could be completely dried out. Try boosting the battery and then charge it for 1 to 2 hours. Check if you're still facing the same issue.
If the issue persists, go to a spare parts store and check the specific battery model number. Test it there itself—if the phone turns on, it’s time to replace the battery. If the problem continues, check the charging port using a digital multimeter.
If the charging port is working fine, the issue might be with the display. Try using a spare display to see if that resolves it. If the problem still remains, it’s likely a CPU issue. In that case, you may need to reball the CPU or replace the motherboard.
Puan 0
1 Yorum:
It will turn on, but then it will proceed to die on the charger.
tarafından
Yorum Ekle
Yanıtını ekle
Alexy sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 4
Son 30 gün: 14
Her zaman: 304
