Ana içeriğe geç
24 Eylül'de piyasaya sürülen Apple'ın 2021 model amiral gemisi akıllı telefonu; 6,1 inç ProMotion OLED ekran, yeni üç lensli arka kamera sistemi ve 5G özelliklerine sahip. iPhone 12 Pro'nun devamı niteliğinde.
iPhone 13 pro battery replacement
I bought the anti-clamp and iphone 13 pro fix it kit to replace my battery on my iphone 13 pro.
I cannot get an initial gap to appear at the bottom of the display after following these directions:
iPhone 13 Pro batarya değişimi
After removing the pentalope screws at the bottom of the iPhone, I tried the following process for 2 hours:
Heat the bottom of the iPhone with a hair dryer for 90 seconds, quarter turn the anti-clamp to increase the suction each time, wait for a minute to see if a gap appears but it never did.
There must be a step that isn’t in the instructions.
Specifically, what to do when the following step does not result in an opening gap at the bottom of the display other than try again:
“Wait one minute to give the adhesive a chance to release and present an opening gap.”
I am trying this repair myself because the apple store refused to replace my battery as the top right corner (metal part not the screen) has a few more scratches than they are comfortable with.
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 1
1 Yorum:
This question was migrated from https://meta.ifixit.com/Answers.
tarafından
Yorum Ekle
2 Cevap
Filtre ölçütü:
If the kit came with a guitar pick like plastic piece, you can try inserting it by pressing it between the frame and the screen (CAREFULLY) with a sliding motion. This can help encourage the phone screen’s adhesive to come loose.
Edit: You may already know this, but just to make sure, if you don’t have a replacement adhesive for the screen, it won’t be dust proof or water proof as it was before.
Bu yanıt yardımcı oldu mu?
Puan 0
Yorum Ekle
Heat the phone while pulling, increase pull force but not too much so the suction cup pops off, find the upper limit of the pulling force then keep it.
Then heat the phone at the area you want to pull apart to soften the adhesive, it will soften and pull apart.
Puan 0
Yorum Ekle
Yanıtını ekle
pete k sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 3
Son 7 gün: 17
Son 30 gün: 37
Her zaman: 721
