Ana içeriğe geç
PS4 Controller model CUH-ZCT1. Released in November 2013 by Sony Computer Entertainment, this six-axis, 3.7 V lithium ion battery controller is uncomplicated to repair. (NOTE: Teardown guide is NOT for this model)
DS4 circle and traingle are bound together(JDM040).
Hello, I've had a problem with circle button(it did not work), I assembled and disassembled gamepad but only i achieved was some weird issue when my triangle was pressing both keys. I decided to replace my conductive flex. My circle button started working, but it is still bound together with triangle (both buttons are pressed when one of them is pressed). When you look at JDM 040 flex, both buttons have conductive trace with each other, I am thinking about breaking it, but I am afraid both keys will stop to encode correctly.
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 0
Yorum Ekle
1 Cevap
Filtre ölçütü:
Hi!
Make sure you have the exact right model replaced for the Button Circuit Membrane. If this is the case, please clean the motherboard (the pins that will push against the button circuit membrane) cleaned with isopropyl alcohol. Otherwise, replace it again and see if that works.
If all of above failed, replace the rubbers as well to see if that makes a difference. Otherwise it is something on the motherboard (but this most of time not the case.
Bu yanıt yardımcı oldu mu?
Puan 0
2 Yorum:
Thanks I will try to clean connections once more but it seems not much can be done.
tarafından
My pleasure! Good luck! Hopefully you will get it fixed!
tarafından
Yorum Ekle
Yanıtını ekle
Kris sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 4
Her zaman: 71
