Ana içeriğe geç
Bir çipin içinde ne var? Nasıl çalışır? Bilgisayar çipleri ayrıca entegre devreler, monolitik entegre devreler, tümleşik devreler, çipler veya mikroçipler olarak da adlandırılır.
Help Identifying a chip
Hello, I have a Vizio S2920w Soundbar which has a blown chip on it. I was wondering if anyone here could help identify it. Its marked 9F 2 and has U7 written on the board beside it. All help would be appreciated!
Resim
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 1
3 Yorum:
Hi, I’m having the same problem. Were you able to identify the component? That would be a great help.
tarafından Paylaş
@albert45304 from whatever is left to identify the component, this could very well be a Voltage regulator. Check on here You can relatively easy identify if it is a V Reg if one of the middle pins looks a bit odd. Again datasheet will show what I mean by that. You can also desolder the component and check the bottom side for what the center pins look like.
tarafından Paylaş
@oldturkey03 Thanks, that was really helpful. It’s definitely one of these.
tarafından Paylaş
Yorum Ekle
1 Cevap
Filtre ölçütü:
It looks like you have some other material to remove and underneath that there are the actual identifying markings.
Bu yanıt yardımcı oldu mu?
Puan 0
1 Yorum:
Unfortunately I cannot remove that as thats the actual plastic itself which has burnt and turned white.
tarafından Paylaş
Yorum Ekle
Yanıtını ekle
TechVid sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 5
Son 30 gün: 22
Her zaman: 260
