Ana içeriğe geç
Meta Quest 3S karma gerçeklik başlığı 15 Ekim 2024'te piyasaya sürülmüştür ve Meta Quest 3'ün daha küçük bir kardeşidir.
How do I fix my stick drift?
I’ve had my Meta Quest 3s since December 31st. Its August 21st as of this being posted, It’s been about a week and i’ve had really bad stick drift issues, especially on my right controller. i’ve tried to recalibrate and clean my controllers, like the official guide says, but i’m still met with issues. What can I do without completely replacing my controllers? help!
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 3
Yorum Ekle
3 Cevap
Filtre ölçütü:
En Yararlı Yanıt
What kind of alcohol did you use when cleaning them? If it's not 90% you won't get the result you want. Can you give me more details about the issue?
Bu yanıt yardımcı oldu mu?
Puan 2
1 Yorum:
In terms of the alcohol i probably didn’t use 90%. unfortunately i don’t remember. i mean, the drift isn’t constant, however, i’m finding that after about a half ish hour of using my headset with the controllers, the drift persists after that. I stopped using it for about two months, came back to it yesterday, and nothings fixed it. i cleaned it again thoroughly changing the batteries and AGAIN, recalibrating the controllers. i guess i’m kind of stuck now. I’ll see if the 90% helps though! thanks!
tarafından
Yorum Ekle
So on my quest 3s left controller when I use a certain move on the thumbstick,example going backwards it just doesn’t let me go back same thing with the other direction that are provided to use in order to move.ive used alcohol wipes even my mouth to blow air out but nothing works so this is my answer
Puan 1
3 Yorum:
Watch youtube video "3 способа исправить дрифт стика на Oculus Quest 2".
I've used method2 but without disassembling. It helped
tarafından
Thanks guys! Update: My stick drift has gotten.. worse. 😭. My friends are telling me I can use compressed air to clean them or, ultimately, replace them. But that is NOT happening anytime soon. Trial and error, I'll see what the video can do to help me.
tarafından
@alexanderpakizh I don’t understand that language
tarafından
Yorum Ekle
how to fix my 3s vr
Puan 0
Yorum Ekle
Yanıtını ekle
carousel0w sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 5
Son 7 gün: 49
Son 30 gün: 168
Her zaman: 2,875
