Ana içeriğe geç
This Nintendo DS Lite was released in 2006 as the successor to the Nintendo DS. Getting inside this device is simple, making for easy fixes.
turn on and then immediately off
My daughter dropped her ds on the floor and now it will turn on and then immediately off. I tried charging the battery and even replacing it with another good battery from another DS we have, but still the same problem. The right most light turns green when powered on for about 1 second but then shuts off
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 24
6 Yorum
trun on problams
tarafından
plz talk to me
tarafından
Ha (that happiness to me to)I don't know how to fix it
tarafından
How to fix a DS lite that turns on and instantly off
tarafından
I have this issue after I rehoused the system. the botton screen turns on, and the blue light comes on, but then shuts off after a second.
tarafından
1 tane daha yorum göster
Yorum Ekle
8 Cevap
Filtre ölçütü:
En Yararlı Yanıt
Unfortunately it could be a variety of problems. Fortunately they all have workable solutions.
Perhaps the easiest problem to fix would be if, when it was dropped, one of the cables became loose or disconnected. In that case all it would take to fix it would be to open the DS up and ensure all the cables are properly seated.
A more difficult one to address is it is possible that when it was dropped a component was knocked off the main board. And it is quite common for an inductor to get knocked loose in a drop, located near the power switch. But it is an easy solder if you happen to work with electronics.
If you want to further diagnose the issue I'd recommend using the following guides to disassemble the device and check for possible damage:
Nintendo DS Lite
Though there is another apparent option which centers around possible hinge damage. Does it appear that there was any damage to the hinge in the fall?
If so you may just need to replace the casing and one of the screens to rectify the issue. In which case the above guides would also be useful.
Also, if it turns out you need replacement parts, this is a good spot to start looking.
Bu yanıt yardımcı oldu mu?
Puan 13
6 Yorum:
+ damage to the hinge damages the cable connecting the top LCD and can give the turn on turn off issue.
tarafından
That´s the answer I was looking for. tnks
tarafından
it work on my ds
tarafından
turn on problams
tarafından
Lol, it's been a long time since literally "jiggling the cables" was a solution. Disconnect, and reconnect, the 3 ribbon cables, works like a charm.
tarafından
Yorum Ekle
one of the connectors is not connected anymore
Puan 1
Yorum Ekle
hold the power switch on a maximum 1 hour and keep the ds game inserted.
if your daughter wants swap the ds game your daughter will need a gba game
Puan 0
Yorum Ekle
maybe it was just from the fall
Puan 0
Yorum Ekle
Hi, if you’ve got no flash screen, consider to try my fix here.
The DS won't turn on. Green light flashes for a second.
Puan 0
Yorum Ekle
The problem might be in the battery compartment
Puan 0
Yorum Ekle
i will try shaking mine and see if that works, since i might just get a new one, if we can't fix it
Puan 0
1 Yorum:
i did not work :'(
tarafından
Yorum Ekle
My aunt’s DS lite’s power switch is broken. I would slide it to the on side but then it just moves to the off side. Is that supposed to happen?
Puan 0
Yorum Ekle
Yanıtını ekle
khan786 sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 15
Son 7 gün: 92
Son 30 gün: 431
Her zaman: 94,069
