Ana içeriğe geç
Haziran 2015'te piyasaya sürülen taşınabilir Bluetooth hoparlör. Hoparlör, ClearAudio+ Teknolojisi ve LDAC Teknolojisine sahiptir. Model Numarası: SRS-X55.
I need help with an issue.
Hello!
I have a Sony SRS-X55 Bluetooth Speaker that is with an issue, which I am trying to solve. However I will describe the issue below.
I spilled water on my speaker’s power button and call button and after this incident the speaker did not turn on anymore;
I tried resetting and charging my speaker multiple times. Therefore both actions did not work. The speaker does not turn on nor it keeps the charging light on while it is plugged in the power outlet of the wall like it use to before the incident.
The battery was still good in my opinion despite never being changed before, because I rarely used this speaker and it was fully functional holding a charge earlier this year until recently when I spilled water on the speaker's power button and call button.
My questions are as follows:
1) How do I solve this problem?
2) Which part could be the faulty one which needs to be replaced more likely?
Looking forward to someone's help.
Sincerely,
Jorge Nicholas.
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 0
Yorum Ekle
1 Cevap
Filtre ölçütü:
En Yararlı Yanıt
@mrfixit50969 this could very well be the button board. Time to take it apart by using this guide Sony SRS-X55 Button Circuit Board Replacement - iFixit Repair Guide Next you want to clean that with some high-grade (90%+) isopropyl alcohol and a soft brush. Check the board for any damaged components. It might be helpful to post some front and back pictures of the board to see if we can find anything "odd". Use this guide Adding images to an existing question - iFixit Repair Guide for that.
Which part could be the faulty one which needs to be replaced more likely? Unless ruled out, my prime suspect is the button board.
iFixit Görseli
Kılavuz
Mevcut bir soruya görsel ekleme
Zorluk:
Çok kolay
2 - 5 minutes
Sony SRS-X55 Buton Devre Kartı Görseli
Kılavuz
Sony SRS-X55 Buton Devre Kartı Değişimi
Zorluk:
Orta
5 minutes
Bu yanıt yardımcı oldu mu?
Puan 1
Yorum Ekle
Yanıtını ekle
Mr.Fixit sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 8
Her zaman: 251
