Ana içeriğe geç
Ağustos 2020'de piyasaya sürülen Samsung akıllı saat. 2018 model Galaxy Watch'un doğrudan halefidir.
My watch will not start
Watch new out of the box and has been sitting on charger for 5 hours. On indication on the watch charging and I have tried two different chargers. Tried the hard reset with the power button and back key at the same time on luck. Tried the both button rest on and off the charger no luck. Suggestions please.
The watch only arrived in the mail today??
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 0
Yorum Ekle
1 Cevap
Filtre ölçütü:
It sounds frustrating to have a new watch that won't start. Here are some steps you can try to troubleshoot the issue:
1. Check the Charger and Cable:
  • Ensure Compatibility: Make sure the charger and cable you are using are compatible with your watch model. Sometimes, using a non-compatible charger can cause issues
  • 1
  • Clean the Contacts: Ensure that the charging contacts on both the watch and the charger are clean and free of debris
  • 2
2. Perform a Hard Reset:
  • Hard Reset Method: Press and hold both the power button and the back key simultaneously for about 10-15 seconds until the watch restarts
  • 3
  • . If this doesn't work, try the following:
    • Alternative Method: Press and hold the power button and the back key while the watch is on the charger
    • 3
3. Check for Power Issues:
  • Try a Different Outlet: Plug the charger into a different power outlet to rule out any issues with the power source
  • 2
  • Use a Different Charger: If possible, try using a different charger that you know works with another device
  • 1
4. Battery Issues:
  • Battery Replacement: If the watch has a removable battery, try removing and reinserting it. If the battery is not removable, you might need to contact the manufacturer for a replacement
Bu yanıt yardımcı oldu mu?
Puan 0
1 Yorum:
Hi @cslpcslp
Your answers seem to be just copy/pasted AI answers.
Please be aware of the Community Guidelines when using AI only to answer questions on ifixit
As the author, you are responsible for conveying factually correct information.
If you persist in answering in a way that may be viewed as AI information only, your answers will be deleted.
Moderator.
tarafından
Yorum Ekle
Yanıtını ekle
Tim sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 2
Son 30 gün: 29
Her zaman: 465
