Ana içeriğe geç
Mitsubishi Lancer'ın sekizinci nesli.
2002 Lancer CK5A Window not reciprocating
I've bench tested the regulator and it's working. The switches driver window relay clicks in both switch directions yet the window still doesn't move. I'm open to any ideas or wiring diagrams.
Cheers team.
Bu iyi bir soru mu?
Puan 0
4 Yorum
@andrewmorg21490 "bench tested the regulator " is that including the motor? Besides clicking, have you checked the relay?
tarafından
Yeah, motor works as it should. Moves the cable up and down on its path. I'll take the switch apart and come back.
tarafından
The "auto-sw" arm was in the wrong position making the switch not work at all. I'll put it all back together and see if it stays fixed 🤣
tarafından
Looks good and works good. It's a silly little 3mm plastic tab the switch is meant to hook on to. Out of all things...
tarafından
Yorum Ekle
1 Cevap
Filtre ölçütü:
Seçilen Çözüm
It's a little ~3mm plastic tab the switch is meant to hook on to, and it should be aligned with the outline on the PCB.
Bu yanıt yardımcı oldu mu?
Puan 0
Yorum Ekle
Yanıtını ekle
Andrew Morgan sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 17
Her zaman: 244
