MS631 - factory testing or reset due to diagnostics?
I am aware this could be an inadvertent diagnostics reset from a technicians repair attempt which did not trip the permanent counter before it was dumped. That said if it the error came from a diagnostic reset error it happened early enough to not be a red flag to sideline it as waste at 21 pages, especially for $59. The unit was already a risk with red flags all over from the beginning given the screen is $200+, brands to the printer and can't be reused. The places with the part will not accept returns due to the branding once opened.
I took the risk on fixing this unit because I know the firmware sometimes revives the touchscreen on some of these prpblem Lexmark printers. The MS631 is one of them. Once it's updatedm it will never happen again unless the screen physically fails.
I grabbed this MS631 because of a bad touchscreen from a company that noted the repair cost for the panel was $200+. I confirmed the price, and the printer pairing issue remains. The MS631 is the same as the MS621 (with a touchscreen, +15k pages drum lifetime, and different toner CRUM IDs), but the price made the risk worth taking, given what the major parts that aren't machine locked are worth.
It turned out to be a bad touchscreen connection that caused the issue, and given that the MS631 is dependent on it, nerfed it and made it "useless", and a very cheap risk. It came from a facility participating in Lexmark SupplyPlus (facility purchases the printer outright but gets a discount on supplies, not the same as the MPS version they had with the MS621 and older, where "contract" units take retail and Contract toner CRUM IDs, and were built with different controller flagging). It's the same supplies I buy outside of it, but with a discount, AFAIK. That’s how I knew it wasn't factory fresh when I got it, compounded by missing drum packing material you would see on an actual 0-page printer.
However, when I did the meter check to make sure it isn't a 100-150k page machine for what I paid, I noticed a 0 page count, but a 21 count on the permanent meter. This is compounded by the toner having 21 cycles; it is also counting, so the page counter isn't disabled. I also noticed a telltale mark on the imaging drum foam seal (entry port on the drum) that leans towards prior use, indicating a possible reset. Here is an example of how it looks when the drum has been run even briefly (14.7k pages, MS621):
Now the MS631 with "0 pages":
This only occurs after you use the printer and complete a print cycle, but some toner may spill during shipping (although it shouldn't be much). Based on those little cues, I believe this was lightly used before I got to it. Someone else's troubleshooting led to a cleared meter, likely ~21 pages before I received it (now up to 28 due to my meter count test, as the logic is that 26 were permanently logged, and I added 2; thus, the permanent counter increased to 28). SO to recap:
- Permanent counter: 21
- Page count (visible): 0
- Drum unit cycles: 21
- Toner cycles: 21
- After testing for meter functionality: 23 pages toner, 21 drum (I ran the device information pages not to burn toner, so it may not have triggered), 23 permanent, two pages printed on the visible counter
That said, I am also conflicted. I checked a NIB (opened, unused) CX431 color laser. I found 26 pages on the permanent counter with all the original unit packing materials, including the ITB protector (no foam or other factory material). It isn't shown, as I didn't consider it in the initial photos, but the MS631 comes with a Lexmark SWP drum and toner (which mine came with). I'm not sure if one can transfer the drums between printers, but SWP toners are locked to the specific shipping machine.
Now for a used CX431:
Meter counts are as follows
- Permanent (Color+Mono): 1,288
- Visible color+mono: 1,257
- All other details are written in Sharpie on this image. This unit has a 31-page gap between permanent and visible (printed) pages, likely due to the complexity of adjusting the CMYK registration on color lasers. The new one is almost as high, even with zero user prints.
Based on these clues and the meter oddity between the two, is this likely diagnostic testing triggering a reset, or a potential diagnostic reset before I even got to the unit? The drum could be genuine, given that I risked losing its current cycle count in my MS621 by performing a maintenance mode reset (1), and it stuck. However, I'm a little unsure.
(1) Put the pitchforks down. The foam seal, where the toner entry port mates with the drum, is degraded due to compression and is partially crumpled. The drum I tried it on is already on borrowed time, as the failure will eventually cause a print defect. THIS IS MY UNIT. THE DRUM IS NEAR THE END OF LIFE. I have a spare.
Here is what I pulled from the printer's internal data that remains:
After putting two pages on it to make sure it is counting:
Bu iyi bir soru mu?
Reposted it due to a bad AI answer removing any reasonable chance I had at getting an answer :/.
Nick tarafından
