HP Pavilion 15 Dizüstü Bilgisayarlar, özellikle 15-eg modelleri için onarım ve söküm bilgileri. HP 15-eg, 15,6 inç ekranlar, Intel işlemciler, DDR4 bellek ve katı hal depolama özelliklerine sahip, hareket halindeyken üretkenlik için tasarlanmış bir dizüstü bilgisayar serisidir. 15-eg ile başlayan model numaralarıyla tanımlanır.
Bu yoruma uygun yeri bulmak için bu konuyu kaydırın. Ardından, taşımak için "Bu yazıya yorum ekle"ye tıklayın.
2 Yorum:
Jed, give us some more information. You just replaced the battery, is that right? Now you're trying to "calibrate" it and, what, it's not working? In what way? Does the battery charge to 100%? Then you use it until it dies, correct?
What exactly is it doing or not doing? The more information you can give us, the better the chance we can help you figure out what's going on.
With only the four words you've said so far, there's not much we can do to assist you.
you had it right installed the replacement [original hp battery] laptop charges
100% has been working fine. It is HP support Assistant that is installed on laptop that is saying something is amiss with the battery. I have no problems with it. Thank you for so accurately solving the problem with so very little to go on. I deeply appreciate that! JED
Jerry Wheeler tarafından
JED tarafından
