Ana içeriğe geç
6 MB paylaşımlı L3 önbelleğe sahip 2,0 GHz, 2,3 GHz veya 2,6 GHz dört çekirdekli Intel Core i7 işlemci (3,8 GHz'e kadar Turbo Boost).
MacBook not turning on
Hey all! I was installing macos mavericks on my macbook, when it suddenly turned off and refused to turn back on again. The charging indicator shows that its charging thogh (the orange and green light) but isnt actually on. What can i do to fix it or what can be the cause? Thanks
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 0
Yorum Ekle
1 Cevap
Filtre ölçütü:
Let's try a hard SMC reset.follow this guide to Step MacBook Pro 15" Retina Ekran 2013 Sonu Batarya Değişimi now with nothing plugged in press and hold the power button for a good 15sec's this will discharge the logic board. Now carefully plug in the MagSafe charger only, the system should spontaneously restart, let it complete the process and do a clean shutdown. Now carefully reconnect the battery and with the MagSafe charger also connected see if that works if it does, shutdown and disconnect the charger and test again. If any of these fails let us know.
Bu yanıt yardımcı oldu mu?
Puan 0
3 Yorum:
Hey til what step? I think your text glitched a bit
tarafından
I figured it out and tried your steps. Didn't work. However when i plugged the charger in and let go of the power button, it turned green, then it went back to orange
tarafından
@zarrar_ - I if it stays Amber, the battery needs to be charged and might need replacing as well. Let it sit a good four hours, then try to turn it on then.
tarafından
Yorum Ekle
Yanıtını ekle
Zarrar sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 5
Son 30 gün: 26
Her zaman: 212
