Ana içeriğe geç
Repair guides and troubleshooting information for hair dryers.
My Rowenta Hair Dryer 2000kw does not blow hot air anymore!
Hi everyone,
I have a rowenta hair dryer which has stopped heating up right away. It blows cold air only. It has 2 speed buttons and 1 cold air (not needed anymore!!!!) one. Can u guys help me? TXXXXXX!
Bu iyi bir soru mu?
Puan 0
Yorum Ekle
3 Cevap
Filtre ölçütü:
Seçilen Çözüm
The heating coil probably has a break in it (most common cause for failure). The problem is getting a good replacement part. It does have a one year warranty: http://www.rowentausa.com/rowenta/frame....
Bu yanıt yardımcı oldu mu?
Puan 2
Yorum Ekle
well I recommend you to buy a new one, normally when it starts to fail it's better to get a better one. If you decide to do that, I suggest the one I use, it's the Karmin G3 Salon Pro Hair Dryer which dries the hair really fast and keeps my hair smooth, shiny, frizz less and healthy. :D If you are interested you can check it out at safrons. com :D
Good luck. :)
Puan 0
Yorum Ekle
well im just gessing but when you turn on the hair dryer check and see if the heating elememts inside are heating up if not then i would replace the heater coil if that dident work then i would do as Brownmoniq says and just buy a new one because if its not the coil then is has something to do with the control board
Puan 0
Yorum Ekle
Yanıtını ekle
Laurie sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 1
Son 30 gün: 5
Her zaman: 5,723
